I have a weird temperature problem. When my car reaches operating temp,
I turn on the heat and the temp gauge drops almost by 1/2. I don’t understand this??
With the heat off, the temp gauge reads where it always has. If I run with the air on
(So the fan is on to cool it) to see if thermostat appears to be working ok the gauge seems to run at the normal range until I turn on the heat then the gauge drops? Oh BTW the Reservoir is full
The heat seems to reflect the drop in the gauge also.
Any Ideas to help me out??
