BurritaSVT
OK I have been doing some serious thinking about the money and the best compromise here.
Sorry I had to start a new post here but I want to really talk about one subject here. And this will be picking with Tom some because I am disagreeing with the first thing he ever told me which is the first........
Well I have a 2.5 liter crank that is in great shape from my last forged motor and it was balanced for pauter rods and 9:1 diamond pistons that were bored .20 over and they were flat tops too.
Now the new motor has the exact same rods but the pistons is slightly larger diameter but it is dished taking away some extra weight too but added back withg the larger diameter pistons.
But Tom told me to stay 3 liter but I would have to buy another 3 liter motor ship it or find a used crank ship it and still have to pay 200 to rebalance it too. So this could cost 600 or more or I can just save 400.00or more by just taking my 2.5 liter to add just some offset weight rebalancing it for the few grams more.
So we know the 2.5 liter crank can hold more than I plan on ever giving it. The 3 liter crank same strength but larger lobes to offset it weight by factory. Which if someone would put it side by side I wondering if the larger lobe would hurt by having more surface area which creates more friction when it moves through the oil.
And if I was to go like forged steel pistons to go over even further would a 2 .5 liter motor change cranks to a 3 liter crank to handle more weight ....nah he would just balance the 2.5 liter crank since the differences I can only see is what the factory does adding larger lobes for more counterweights. Which is what a good reputable motor shop can do by just adding weight by welding in the holes drilled on the end of the crank.
I went outside to see what they did to my 2.5 liter crank to make it balanced and they filled 2 hole of the three on the lobe to make it right. And that littel weight was enough to offset forged I beams rods and heavier psitons then that means the few grams difference now should be a walk in the park for the guy since he still has anouther hole to add weight plus by filling the hole eliminates drag since it makes a smoother edge too for oil friction.
I want someone like Tom or fastcougar etc. to give me a detail answer on why I should not go this direction and go buy another 3 liter crank instead. Now remember all my block and parts are still good I only lost a Pauter Rod and a crank here.
Hope I didn't bore anyone here but I just hoping that my knowledge is right on what I think is better.
