kouksie
Hello,
I drive a 1998 Contour SE, 2 liter, 4 cylinder automatic.
I was on the highway a couple days ago, and my car was acting up. I would hit the gas and the RPM's would go up as normal, but the transmission wouldn't down-shift, and when it finally would shift, it was VERY lurchy. I checked my fluids, all were normal. It seemed to happen after an hour of driving. I would turn the car off for a half hour or so, and then the car would drive normally for about an hour, then start shifting irregularly at random speeds. I stopped in a town with a diagnostic tool, and the error code was "708". They looked it up, and apparently is a transmission sensor error, which causes erratic, irregular shifting. They assured me that it would be safe to drive, so I made it home.
I took my car to the dealership, and ran the diagnostics, and tell me they are recieving no 'error' codes, and that it may be that my overdrive switch is not working. My O/D switch has not worked since 2000, and I find it hard to believe that it would be caused by an O/D problem.
I'm unsure of what to say. I told the dealership to look at the car again, because I was floored that they were getting no error messages, when I saw people hook up diagnostics to the car and saw the display message of 708. The car needs to go out on the highway, and I can't afford to be lurching again on a one-lane highway.
I hope this is specific enough, but I would appreciate some input/suggestions. If you have any questions, I would be more than happy to answer them in order to get some more advice. I'm just tired of the dealership!
Thanks!
Thanks!
