Smokin98SVT
$700 https://atlanta.craigslist.org/wat/cto/5993977805.html Ford contour svt for sale salvage title 1998 Apx 170000 3.0L engine from a 2004 Sable 99k miles Only a few thousand miles since installed. 2003 Tribute oil pan Engine harness from 99 cougar (fixes 98' harness issue) 5 speed MANUAL transmission New LUK Clutch 4 New kumho tires (2 not mounted yet) 215/45 R17 Also have original 16" wheels Leather interior looks great, midnight blue color. New KYB front struts New front control arm bushings New diehard battery New fuel pump New coil pack/plugs New MAF sensor New TPS New IAC New DPMS New speed sensor New water pump New brake master cylinder Emissions done in Nov. 2016 K&N air filter Ton of recipts Bad: Was driving it regularly until I got rear ended. Trunk is damaged but fixable. Windshield needs replaced. Not hit hard enough to set off the air bag. Insurance totalled due to the age of the car. Can be repaired then inspected for about $100. The title then can go from salvage to rebuilt. Can be driven around the neighbourhood but with no tag, cant drive on main road. Starter bearing sometimes noisy but works fine. Parts available at pull-a-part; tail light $21, hatch $70, bumper $42. Windshield replace is about $200. I have too many projects at the moment.
