96MystiqueGS
I should be doing a junk yard run on Wednesday. If any one needs anything that isn't too big I can pick it up for you.
1. An axle bolt cover: metal, stamped with ford.
Not sure if the E1 has front calipers on it. Not 100% sure what you are talking about, is it the metal thingy on the top of the caliper? Would it be on any other Contique front caliper? If a picture is available that would be helpful too.I could use the metal clip from a front caliper off of an E1.
I think I know what you mean... Round, on the back, visible through the center of the rim (when center cap is off). Any certain way to remove this?
I remember someone else had the same problem as me and when they went to the dealer, they found out they were different.
If you can fit a tail light into your pants I'm sure that the clip should fit. :laugh:
