C captastic CEG'er Joined Aug 17, 2012 Messages 239 May 4, 2015 #1 I need to change the rear wheel bearing on my SVT. I've done the fronts several times (taken the knuckles to a shop to have a new one pressed in). From looking at a diagram it looks like the rears are pressed in as well?
B BrApple No Life But CEG Moderator Joined Dec 23, 2001 Messages 21,731 Location Gales Ferry, CT May 4, 2015 #2 IIRC you just buy a new hub with bearing. Remove what looks like a drive axle nut and it will come right off. Check out rockauto.com
B B3NN3TT Hard-core CEG'er Joined Feb 9, 2005 Messages 1,871 Location Columbus, Ohio May 4, 2015 #3 That is correct. It is a very simple job compared to the front wheel bearing, which is a headache.
