Nice write-up
I am currently dealing with this issue also, on my SE. I decided to do the pre-98 trunk lid instead. Until I finish painting the replacement lid, I removed the spoiler, and used rubber 3/4" differential plugs to seal the holes up (some need drilled out to be the correct size/round.).
I've repainted my spoiler 3 times, because the clear coat kept peeling off. I don't think the damaged spoiler mounts were from lifting the lid by the spoiler (but that could have worsened it.). It actually seems like the spoiler has shrunken, or started to curl up... probably sun-damage. Once I unbolted the spoiler, it was definitely way more arched than it should have been. I don't think the JB Weld would hold the tension that my warped/arched/shrunken spoiler would put on it, if repaired this way.
Like every thing else on this car, all the normal problem parts are getting deleted, or replaced with non-problematic parts... Sun-roof motor replaced with European hand crank, IMRC deleted, pre-98 dash swap, 3L swap, and now spoiler delete/pre-98 trunk lid swap.
How long has your spoiler repair job held up, so far?
