bishop375
And, since I lack most mechanical knowledge, was wondering wth it was!
Thanks!
Thanks!
Looks like the heat sheild/shell off your cat.
throw it in the garbage and call it natural weight reduction haha
I thought about this, this morning. As suggested by Fav, you should put the shield back and use one of those muffler repair kits (with the straps, nuts and bolts). About $8 from Autozone or Advance. Need shears to cut the the strap for the correct length. I had the same issue but it did not fall off but was making a loose dink sound the first 15 seconds or so during start up.
