Urgent Help!!
trhlz1222
Holly Springs and Parish
alright well just put my uim lim tb and everything else back on. car wont start. just wines and wines like ive never heard before. ive tried priming it like the how to says and still nothing. please help.
Does it start up and then stall or not start up at all. Listen for air being sucked in somewhere on the UIM to make sure that it's not one of your vacuum lines. This is exactly what my car did and I found there was a vacuum leak and that fixed it.
it doesnt start up at all. it started to sound like it would. i could hear the exhaust kind of bellow and back fire a little bit then stopped. i read on the old forums that to try WOT(what is that?) for 20 seconds and if that works then it works. if not it also said to pour oil down the heads which would be really hard seeing as i just changed the oil and have none left and i would have to take everything apart again. ill try what you said tho.
the starting it wot, is if you flooded the cylinders. Usualy that happens is it starts for a split sec. and then dies. Like if you dont hold the key on long enough. I doubt thats your prob. Like everyone stated you need to look for a vacume leak.
no vaccuum leak of any kind. i ended up starting it up i had to hook it to another car for a jump but once i got it running and cleaned out it runs great now. i just held the throttle open and kept trying it and it finally turned on.thanks for the help
