striker2
Official CEG Vendor
have to log in to see the pic.
jamesmason;122559by the way what controls that light. does your car have a tcs on it?[/QUOTE said:I just spliced the O/D light to the next socket over because it says "SPORT" I also found something else new... There is a picture of a strut next to the sport light... kinda makes me wonder what thats for.
I also re did a little of my interior, but I'm not going to make jamesmason keep being my errond person on this. Thanks for the posting of the pics man.
And Locos, I keep trying to go to the shop that put the muffler on and they want $80 to relocate it even though I told him I wanted it even with the lip and the canister up toward the car not showing as much... I'm going to keep fighting it, but until then.
Only the 99 and newer zetecs use returnless fuel rails. This is actually easier to work with, and the Focus SVT fuel pump is a drop-in replacement that flows better than our stock one.
To answer your very first question, the only differences between Zetecs are silver top (pre 98) and black top (98+) engines. The newer ones have VCT which is a pain.
To make the most power NA, you should invest in an FRPP head. This has been proven to result in the single biggest power gain, and is probably the most bang for the buck as well. Don't bother with stuff like underdrive pulleys, etc, until you've changed the head and cams. Upgrade your exhaust, intake, and head, and go from there. If you want to go turbo or S/C later, you'll be good to go.
That's interesting. So we actually have 4 different "groups" of Contour Zetecs...
95 - Hydro lifters with OBD-1 PCM (Single timing belt tensioner, single lower idler, EGR)
96-98 - Hydro lifters with OBD-II PCM (Single timing belt tensioner, single lower idler, EGR)
98-99 - Solid lifters with OBD-II PCM (Timing belt tensioner, upper idler, lower idler, VCT)
99-00 - Solid lifters with OBD-II ????? PCM (Timing belt tensioner, upper idler, EGR)
Does anyone know if the 99-00 Zetec Contours also have the OBD-II rev 2.0 PCM? That would be VERY interesting because the 4F27E transmission would just mean some minor rewiring and a chip.
Also, do the 99+ Zetecs have the oil filter mounted horizontally to the block(just like the Focus)? How about the 98-99 Zetecs?
BP
the big red thing looks like wring for an amp. the black tubing that ends by the battery and has been cut is a vent for the tranny. im not sure why its been cut but i would replace it with the right length tube so you can mount it sidways like it was originally, you dont want dirt or anything getting down in it.
ding ding ding...you win...
Do I actually pull the sensor out of it's casing when I put the SVT MAF in place of the 'tour?
What are you expecting to gain doing 'fuel/air' upgrades on a stock motorFirst, the big red wire is for the amp second, I'm doing a fuel/ air upgrade, but every MAF I have looked at has differant connectors, I'll try to take pictures if I can.
What are you expecting to gain doing 'fuel/air' upgrades on a stock motor![]()
