How I filled my engine a few years ago, experts welcome!
Obtain the required amount of 50/50 mix coolant, specified in service/owners manual. Park car nose high uphill or on ramps, so trapped air will tend to go to radiator. Take off the upper radiator hose, with angled funnel or through hose, fill up the radiator with the 50/50 premix, which will fill the engine partially, let in settle in (gurgles). Add until it will not accept any more. Reinstall hose/clamp. Pour coolant in the heater hose that joins near the thermostat, which will get some coolant in the cylinder heads of engine as well. Once full takes a few tries, reattach hose/clamp. Fill up reserve tank to max, put pressure cap on. Add coolant to engine if reserve tank gets near bottom, when engine has cooled. As it warms up, check heater is hot. Check coolant capacity. When you get most of the coolant in, run engine to full warmup, let cool, add to 1/2 inch above max. Check a few times after driving.
