O outkast CEG'er Joined Feb 7, 2002 Messages 85 Location Edgewood,Maryland Apr 15, 2007 #1 I have a problem with water leaking into the(front) passenger side foot area!The water is from a rain storm,and not antifreeze!I,d like to know if anyone had this problem and how did you fix it.
9 96MystiqueGS Veteran CEG'er Joined Jan 26, 2006 Messages 632 Location Wilkes-Barre, PA Apr 15, 2007 #2 Most likely leaking from around cabin air filter area... check this post out for some info: http://www.contour.org/ubbthreads/showflat.php?Cat=&Board=trouble&Number=450981&Forum=trouble&Words=passenger%20side%20water%20leak&Match=And&Searchpage=0&Limit=25&Old=allposts&Main=450981&Search=true#Post450981 and this one too http://www.contour.org/ubbthreads/s...ld=6months&Main=376894&Search=true#Post378401 Last edited: Apr 15, 2007
