OK, I didn't even bother cleaning it. And they are adjustable enough to set the sideskirts on the ground. The ride is stiff, but doesn't rattle your fillings lose and the car doesn't pogo. The main reason for this is the progressive rate coilspring (compared to the linear rate spring used by the ground controls) and the 36 way adjustable valving. The shock bodies are also made of billet aluminum and are threaded so they are going to weigh considerable less then most other setups.
So here is a few pics, nothing special, but its all you're getting this close to Spring Zing!
The front with wheel on & off:
The rear with wheel on and off:
