CSVT#49
Addicted CEG'er
Ok because of the latest Morette post I've decided I'm going to just buy a pair of projectors with my credit card to make just one headlight and then use the same projectors to make the other light to save on money. This way I can get the process rolling.
My question is if someone wants to upgrade to HID lighting and maintain usage of high beams, wouldn't you need two low beam Hella 90mm (like Quicksilver, Milan)? As they are the true projector housing were the 90mm high beam is not.
Using two low beams
Using one low beam one high beam
And then of course there is the halo option, which despite a few I am really debating about doing
So what are your thoughts and needs I guess...
Heres what I'm looking at for an upfront cost to get these going:
Description Price Quantity Total Modify Delete
68137 90mm Low Beam Headlamp, DOT, w/65w H9 Bulb, Each Requires 1 H9 Connector per Lamp, HL87193 $58.75, $117.50
87193 H9 Connector w/pins & seals, Each $6.70, $13.40
Subtotal: $130.90
Standard Shipping: Priority Mail or UPS Ground $9.00
Total $139.90
I already have the parts to build the halo's. Although before I drop 140 bucks I want to make sure that is what the majority of you guys want to go with. So that if I rebuild these things for anybody people will be happy with them.
Using two low beams
Subtotal: $130.90
Total $139.90
