realness1978
I bought my car in for a timing belt replacement at the dealer on Thursday. I got a call back from the dealer on Thursday and he said the timing belt tensioners (not sure if that is the correct name) blew up and I needed to replace them because all of the wheel bearings came out. He told me the car would be ready by Monday. I got a call back from him today Monday and said the serpentine belt tensior needed to be replaced because the belt or something was not going back and forth like it is supposed to. So I said go ahead and do what needs to be done to get it fixed. Then I get a call back around 10:00 pm and he tells me the car is not turning over because there is an air leak coming from cylinder 2. He performed a compression test. Now he’s telling me they can do more diagnostic by removing the head to see if it is cracked. They are not sure if it is the top or bottom. Also they are not even sure if this is the cause of the leak. Also they said it is going to cost me a tremendous amount of money to check to see if it is cracked and they are not sure if I want to spend that type of money. Also they still want to charge me for the timing belt replacement and diagnostic and the serpentine belt fix. So basically they are giving me these two options 1) Spend more money on top of the $800 job for timing belt replacement, diagnostic and the serpentine belt fix to determine the cause of the engine not turning over. Or 2)Spend $800 and take a car that does not even drive.
Any advice you can give would be greatly appreciated. This doesn’t make any sense at all and I feel like I am being taking for a ride. I bought the car to the dealer thinking I will get the job done right once and for all but apparently this is not the case at all.
