ArtSvt
needs more pictures! :laugh: Of what is all included with this GB? When will it all be ready?
Yes I know the svt motor has higher rpms due tothe cams and intake setup. And I ahve seen also dyno numbers with a straight 3L with svt cams and then the SAME motor with 3L cams. Makes alot more power with 3L cams. Yeah the svt cams you get more rpms but less power. Whats the point in that? And again why wouldnt they use those cams on the 3L in the first place? Ahhh cause they wasnt designd for a ovalport cause the cam profiels are WAY off.Yeah you can normally get 20 more hp with svt cams on a 3L....when you got the heads to go with it lol. ?And then you get alomsot 20 fptq less also
Oh yeah and another thing ur dynochart is in sae which give you high numbers than std. Mines in std }~
I didnt read it anywhere I seen dynonumber. And Yes they made pretty much the same hp the taurus making like 1 or 2 more but hte taurus also made 200 fpt VS the svts little 170 tq. That 30 more foot pounds of tq. And that dyno shows 217 and a little 189. My straight 3L made like 215 hp but the toned it down because it had a idling issue, but still put down 203hp and 210 tq at teh wheels. Thats 21 tq more than that motor and only just over 9 hp less. Ill trade the tq for a little less hp. Which if I took it bnack and got it retuned I bet it would make more than that 217 with this dif intake I have now
Well buddy if it make more tq then how come that SAE max tq reading is only 189 VS's my 210.4???? And you are wrong about 3L being matted to a ATX in EVERY app. Theres the AWD 3L jag that comes with a MTX75. THeres also the lincoln LS. And lets not for get the twine turbo 3L noble matted to a 6speed
Please quit regurgitating what 1 other person said until you understand what you are puking all over this groupbuy. There was one guy on FCO that was going to do back to back dyno's with his 3L.. with SVT cams then 3L cams. To my knowledge, he never did so as he never updated that thread.No you are wrong sae is the raw hp numbers before it has been smoothed over and calculated. Which normally going to give you higher number and which alot of crap happend with manufactures cause they giving fauls numbers by giving the SAE numbers. ANd yes I know the TQ falls off and is peak at a low rpm. As does car like z28 gto's ect. There lower reving engines just like a 3L. I could sya look at me tq at "said" rpm rang and the svt motor would even be close cause its tq peaks higher. And next time clarify cause you said ALL 3L apps
contour2gq is a troll. Apparently he emailed Terry and is trying to get him involved in this O/T debate.1. contour2gq, if you keep pissing up this group buy thread, you will be banned.
2. If you want to have technical discussions on this subject, feel free to start a new thread, or continue a relevant thread in the 3L discussion forum. And if you want to have technical discussion, you better bring real tech, and not straw man arguments based on quotes from other people and dyno plots that were obviously manipulated by the operator to make you feel better about your setup. Feel free to bring Terry into the discussion as well, we have long maintained that Terry is welcome to return, all he has to do is ask, and agree to follow the same rules as everyone else.
3. I'm sick and tired of people attributing a god-like status to Mr. Haines. Yes, Terry is an engineer, and yes he was involved in the early contour program, but my god, the way you guys talk about him its like he did everything on the program all by himself. There are hundreds, if not thousands of engineers working on these types of programs for OEMs, Terry was ONE GUY, IIRC was a prototype coordinator while he was on the program, not an engine designer, or even an engine component designer. Further, every single person I could find within Ford that remembered him, did not remember him with warm regards, and I'm pretty sure it wasn't because they were jealous.
Terry has spent plenty of time studying the Duratec, and the MTX-75 and his technical opinions are certainly of value, but they certainly are not the final word on all things duratec. I've got friends still closely associated with the Duratec program within Ford, and they run engine dyno tests virtually every day on various configurations of 3.0L Duratecs, and thier opinions don't always line up with Terry's.
how is he a troll? He has a silver 3l svtcontour2gq is a troll. Apparently he emailed Terry and is trying to get him involved in this O/T debate.
Well, ok... not a troll, but he's only in this thread to argue.how is he a troll? He has a silver 3l svt
Anyway, we should not drag anyone into our arguments that hasn't voiced the opinion themselves.
