bxd20
I'm doing rear struts on a friends 96 4 cyl with rear drum brakes. The HOW-TO says to undo the brake clips. No mention of disconnecting the brake line.
This car's brake line is rusty in spots, I need to be as gentle as possible. For those of you that have done this job, did you disconnect:
1. the clip on the side of the strut?
2. the clip on the inside fenderwell?
3. the clip by the wheel cylinder?
All of em? one or two of them?
Any tips would be appreciated. I want to make sure the rubber portion of the brake line is all that has to flex, and nothing breaks.
Thanks!
Thanks!
