Yeah, it's the same process for CS3 as well, File>Automate>Merge to HDR Here's something i'm noticing though when I'm using my camera... It has a feature which will have it do a series of 3 shots, and the current setting is +/- .03 Now when I view the photos though in CS3 or Photomatix, I get the same setting for 2 of the pictures... For example, instead of getting -.02, 0, +.02, I'm getting 0, 0, +.02 Now the photos I were trying out tonight were just some around the house, but it was really really dark... could this be the problem? Also my settings allows for +/- .03, .07, 1.0 I know it matters, but for night shots and day shots should it really matter that much in difference? Or is one setting better for say day or night.....? I know if I put my camera on Picture mode I can manually edit my +/- setting between -2.0 and +2.0, The only problem on that setting though is that my flash stays on Auto, and I don't seem to see any difference in the photos... Also with the manual settings and then going to the Multi +/- setting which does the +/- automatically still seem to do 0,0,+.02 ..... Okay I think I may have got it, I've been playing with it in between each sentence... It looks like I can do it, but I have to manually do it, Which sucks because I don't have a tri-pod...
I have to manually set the flash off, and then to the exposure (Is that the right term?) +/- manually setting it to -2 , 0 and +2. I guess another question I have is, I'm assuming the farther apart the values the better you're HDR will be in the end or no? like -2, 0, +2 versus -.03, 0, +.03?
