I replaced my right rear brake line and hose in my 98 svt. Where the metal line meets the brake hose near the right rear strut there is a metal cylinder between the two. I believe it is some type of a one way valve for the brake fluid. The trouble starts when i try to press down on the brake pedal to bleed it, fluid will flow everywhere except into that cylinder and into the caliper. The bleeder screw on the caliper is completely removed. I can take the cylinder off and i can get flow from the metal line. I looked on my 99 svt and it has no such device.
Any ideas?, i have the camera charging right now if someone needs a visual reference.
best i can do for now
line from front metal cylinder Rubber brake hose Caliper
______________000000000000_________________________
direction of flow ->
