Only hook up the 4 channel first. See if that is where the noise is coming from.
Do a simple 1 amp install, Power, Ground, Remote, RCA. No cap.
See if that eliminates the noise.
Seems you may have to rerun the RCA's or......just unplug em from the deck-side, and wire them straight in over your center counsel or somethin to see if that helps eliminate the whine, if it does, then you know its the PCM or whatnot up front thats interfering. But its good you got a block or two, and ran your grounds to one location.
Dont double ground your equipment.
In with ground at CAP, then into AMP. In with power at CAP, then into AMP.
But for now, to eliminate the source of the noise, just install the AMPS by themselves, or one at a time, specifically, make sure you can get that 4 channel running with no WHINE, then go from there.
What if the rca's are going by the PCM or the ECM? Would that make a difference? I've tried running a ground from the stereo to the battery and it doesn't make a difference.
likely, it would pick up some kind of power source you ran it by, and cross it into the amp for sure. Try to play your RADIO, and at the same time, move and wiggle your RCA's by where you think the problem MAY be in the RCA's.
Ive got my RCA's ran to the right side also, close to the glovebox, and down under the kick panel/door sill covers.
Power I got ran to the left side. But your battery is in the back in your ride. WELDING WIRE??? Ummm....Stainless steel? I dont think thats good at all dude.....I would think that would pick up something nasty compared to copper..
So ya ummm, new wire to battery.....
And try to wiggle those RCA's....
