okay.
in order to change what the PCM is seeing
or doing you need to be able to alter it in some way.
- There is the XCAL2(or 3, now) which alters the STOCK PCM's actual code. there is nothing to solder on, nothing to attach, no piggyback methods..
- You have a PCM chip you can add to the PCM.. it alters the commands given to the car. You(or a company) have to open your PCM itself and solder (or clip, nowadays) the electronic components to your stock PCM
- as a smaller section to PCM chips, you can get a "flip chip", which is installed the same way with some additional wiring running to a switch. The switch controls which "tune" program the chip will run. (aggressive/more power/less mileage, or safer, longevity, more mpg etc)
Now, once you have a method to modify the PCMs output/input you can tune it.
- You can "dyno tune" it, but the dyno shop needs to be able to communicate with your specific method of PCM alteration. (ie.. if you have an Xcal, they need to "support" an XCAL at that location)
- email tune it (which is what "most" tuning methods will come with. You get a VERY basic tune preloaded on your chip based on engine size and APPROXIMATE mods (if they go that far)
So.. no matter which option you do, there ARE possibilities.. sure.
My choice?
Obtain an XCAL2 and get it tuned via Nautilus Performance (Tom is, without question or debate, the number one tuner for the Duratec platform out there.. bar none..)
he will send you a tune to upload with your XCAL and then you can drive around while "logging" your driving.. send those logs back to Tom and he will further tailor the tune.. upload, rinse, repeat until you are tuned to the max. No dyno trips, no dyno pull $$, no soldering, no worries, and being able to rest knowing you have the MOST for your money
Other companies give you one tune, the initial one mailed with your chip) and you PAY for another one
How do you KNOW you need another one? you don't.. the car has to be un-driveable enough for YOU to realize you aren't "as good" as you could be, then YOU have to pay again to retry.
so...
cliff's notes.
XCAL
Tom
sleep well
