Lord Stanley
Well on my way to college today I turned on the defroster full blast and was met with an awful smell... I turn everything off and kept on going... I was early (and still am) to school so I went to Walmart... I opened up the hood to find smoke rising from where the serpentine belt was... On closer inspection the smoke was coming from the A/C pulley area... I felt the belt and it was not hot... I let everything cool off and then drove to school and checked it out with the car running... The pulley is rotating, but it appears to have a slight wobble... I am assuming that the pulley bearings are shot?
Or could it possibly be the clutch? :shrug: It was not smoking after driving the few miles to school, and during that time I never used the A/C or defroster. Also, when I turned the defroster on during the main trip to college, the engine seemed more strained under usage than ususal, so IDK...
Since a new unit must be $$$ (unless it is the clutch), I am just going to pull the A/C fuse and put a shortened belt on it (unless it is the clutch
)... So is replacing the belt an easy job to do in the middle of winter, or should I just take it to a shop, and how much would this be?
On the other hand, changing the clutch does not look that bad, would I even need to take the motor mount or belt off to do this?
Also, I was hoping to be able to wait to replace my belt (if it is the clutch :laugh
because the grooves in my waterpump pulley seem to be cracked, and I assume this is not normal? Are any junkyards open this time of year to get a better pulley for it? And those four bolts are NOT TTY right?
Ugg :blackeye:
EDIT: I assume one way of testing it would be to drive back without using the A/C or defroster and then see if it smoking when I get home... If it is not then I could turn on the defroster and see if it starts smoking... That should indicate if it is the pulley or clutch, right?
Ugg :blackeye:
