I just removed my timing components and was wondering what your thoughts are on replacing the timing chain tensioners at this time?
Would you recommend replacing as a preventative maintenance thing or should I just keep the ones that were in there?
Is there something I should look for on the current ones to indicate wear and that I should replace them, or something I should do to test to see if they are still functioning correctly?
I don't want to spend more money if I dont have to but I would also hate to have them go bad 10,000 miles down the road and have to go through much of this work again, or even worse cause more damage.
Mine appear to be fine, and working properly but I'm just asking to see what others thoughts are. Maybe you've been in this situation and didn't replace it but later they went and you wished you had?
My car is a 1998 SVT with ~130,000 miles on the original motor. Bought from the original owner and he didn't say anything about major service being done on these parts/areas.
