TourEnvy
Does Steeda make a short throw shifter for 2000 CSVT, If so please link me. Thanks
I thought the riser plate was only needed for 98's and 98.5's? Do you still need it for 99-00? I obivously have the riser plate because I have a 98.5.
Reebs
I believe any Focus 5speed with the MTX-75 transmission will work fine.
Mark
2000 SVT's don't need a riser plate! What you'll need to do, is remove the sound deadening panel, which can be accessed from below the car. Just remove the exhaust heatshield, and you can loosen the 4 bolts holding it on. I used a piece of plexiglass to cover up the hole, or you could use any sort of metal or even ABS plastic. The piece that you remove, actually protrudes up into the car, which doesn't allow enough room for the Steeda to move freely. Let me know if you have questions.
Mark
B&M's work pretty good.........how much different are they?
