wo0t!!1!
I fixed up some stuff with the Mystique.
1. Interior lights turning on now with doors. Not actually sure what caused it. I checked all fuses, changed the relay, no difference. All I did was plug the clock and defroster back in, then it worked fine. I thought that it was causing the circuit to be incomplete, but I unplugged the defroster and clock after but the lights continued to work fine. :shrug: I did have to changed 2 door sensors though. Opening the front doors didn't always kick on the lights. Wiggle the switch and it would work fine. Fixed now.
2. Door handle light replaced. Pulled a couple from the junk yard in some Pre-98 Tours.
3. Trunk light pulled from my parts car and put in. I can see in the trunk at night now.
4. Trunk release handle working now. The switch was flipped inside the trunk. So Po, how long have you been opening the trunk with the key because of that? :crazy:
5. Replaced blown front door speaker with one of my stock SVT speakers. Sounds 1000 times better now.
6. Clock bulb installed.
7. Broken weatherstripping on drivers door replaced.
8. Doors greased up and smooth now. Could barely open the rears and all my neighbors could hear them a mile away before. :laugh:
I went to the junkyard for the dash bezel and courtesy lights but they had no Pre-98 Mystiques.
Only one Mystique, 98.5-00, and of course didn't have the parts I needed. New trunk struts, headlights, license plate frame, battery coming soon. It doesn't look like the outter tie rods were the problem with the steering now. They both look fine. Problem is coming from farther inside the steering rack.
I took the Mystique out tonight to run some errands and I love it. Very smooth and comfortable to drive. My SVT is a little too rough when I want to just cruise around and relax.
