Hi all. I did some searches on the EGR code (PO401 I believe) that says "EGR flow insufficient" and though I'm confident I can fix it, was wondering if this could be causing a loss of power? I have a 98 SVT and it seems to be missing around 20hp up top. The power comes on fine up until around 4000 or 4500 rpm when it seems to just die until redline. This is consistant in all gears and the EGR code is the only code I'm getting. The engine was just recently rebuilt by my brother (heads, timing gears, sensors, etc.) so I'm praying that he didn't mess up the timing. I guess that would be my second question, if the timing was just a little off would it cause a loss of hp? I was always under the impression that a car would run like garbage if the timing was even slightly off but mine runs perfectly smooth but just seems to be missing power up top. Any imput is greatly appreciated.
