dannimarieiro
i installed one there is adapters in the kit and you have to install a t connector where the oil temp sending unit is by the starter i believe,hope that helps
is this where it is??what the guy is pointing at is the oil sender connector??and where im suppose to connect my oil pressure gauge to is right beside that and use a t fitting???
