sportracer
Ok here is my problem, When I start up my car it kinda idles but sounds more like its misfiring but I don't think it is since the check engine light is not blinking( on but not blinking, A o2 sensor is causing it to be on, like that before when engine was running fine.) and my tach is not working and when I go to put a load on the engine by revving it up it dies like its not getting gas or air, but when I let off the gas it comes back to idle. Sometimes when I push the gas it revs up like normal and sometimes it doesn't do anything. What could be the problem(grounds, vacuum hoses, connections, bad pcm, ????) Any help would be great.
Jesse
Edit: By the way its a 1998 Mystique with a v6 automatic
Jesse
