AndrewM6097
So i've been chasing this rough idle problem for a while now. The engine dips to about 700 rpm and raises back up to normal between 5 and 10 times after coming to a stop. The car vibrates as this is happening and the lights dim quite a bit while this is happening. I've tried numerous things, like replace vaccum hoses, clean MAF sensor, ive sprayed carb cleaner to find a vaccum leak, replaced battery terminals, rotated MAF, IACV, fixed an exhaust leak, reloaded my tune, i tried stock setting on the ECU also. Nothing has changed.
I'm thinking it might be my ALT taking a dump. The "Big 3" are upgraded, and the fix for pulsing lights has been done. Could a bad alt cause a rough idle like this? Would it be worth it to pull the alt and have it bench tested? I've pulled it a few times before so its not too big of a deal.
Also the EGR system is out of the question, as it has been removed from my vehicle and my tune supports it.
