yamaha racer 686
what should my first mod be? just gauging interest
			I did the foglight mod.
does anyone kno if the bat intake with remote air is good cause i have a 1999 se mtx v6
I might try to look for an interior switch for the sunroof switch at the junkyard ....
I can tell you how to make a pre-98 switch work if needed ...
Does it light up?
yes ... from what I determined the post 98 switch gets its power from the power being supplied ot the switch and you just add a ground for the light ...
on the pre-98 the light has its own power and ground seperate from the switch ... so you just splice two wires not one to make it light up ... this is what I did ...
also I think I posted how I did it on the old boards ...
