TRicker
okay peeps. so i went to the local U pull lot today. i found a 01 sable.
totally stoked at this point. 1 degree weather and 30 MPH winds aside.
i needed to get a 60MM tb. the 65 doesnt allow me to have a IAC and its also a couple mill bigger than the UIM outlet.
i took my car apart to fix the vaccum leak i found. Turned out i had a broken UIM bolt and i needed half a LIM. i found that, plastic valve covers (to keep heat off my UIM and save weight) and a 60mm TB off a 99 taurus split port. so im gonna optimize the 60mm and possibly up the size of the plate and have the tb machined to hold a bigger plate.
also i got the 99 tB bracket. if you ever looked at a 99 taurus split port you would know that it has a cool little plastic cover that covers all the throttle/cruise cables and assembly. so im gonna get the rest of the cables when it warms up this weekend and do the whole conversion. I also got a new line for the PCV system, which is black and the correct size. Im gonna paint everything satin black that isnt black yet, and build a custom cover for the battery and a custom cold air box with a new KKM filter or equivalent on it.
so the engine bay will be blacked out and ill be runnin good. when i deleted the EGR the rest of the way, i figured out that the tube going into the manifold is huge and restrictive. so i cut that off flush and silver soldered the end shut so it wont leak or create any sort of turbulence. i also noticed that from teh factory, the PCV outlet was backward and it has a weird angle on it so it was making some intake blockage as well. Im so excited my car already rips and its gonna be nothin but better after all this.
