2001 Mercedes Benz C240 Serpentine belt without AC compressor
Nim
Be Gentle I'm New Here
Winchester, CA
Hello,
My car broke down due to AC compressor stuck with the belt broken. I need to bring the car back home about 70 miles. How do I replace a belt without using the AC compressor pulley? What is the size of the belt without the AC compressor? Appreciate your assistance.
You are unlikely to find Mercedes-specific info on a Ford Contour forum. To give a general answer, on some cars you can bypass one accessory like the AC using a shorter belt, on others you can't, due to the pulley layout. You could get the length about right using a piece of string. When my wife's Ford Freestyle had a siezed AC compressor / clutch, I was able to limp it home with no belt - but on that car the water pump is driven off the cam not the serpentine belt, so I was "only" lacking power steering and alternator. Not sure that it was exactly safe as the steering was VERY stiff.
Also - if the issue is an internally seized AC compressor and the clutch/pulley bearing is OK, you might be able to put on a new normal belt and just don't use the AC at all for the trip. On my wife's car it was the pulley bearing so that wasn't an option.
