Nima,
I'll just respond to both threads here.
First off, I did not say the two were identical. I did however say that this intake is internally @ Ford known to be a good piece, up there with the ST220 (obviously not
as nice). When you've got contact with people that have lunch frequently with the engineers that design and work on the Duratec, let me know.
And for what its worth, the IAC was not the only thing... but was one thing the prevented the hood from closing. I did however successfully close the hood with no problem last night, and the intake mani was not even bolted down all the way! with the IAC brought down a bit it wont be an issue at all. Also I can't say if there is any coilpack issue, since there was not one bolted up to the rear cover on mock up. Not a big deal to me, I wasn't going to mount mine there anyway...
I wasn't trying to dig at you directly... But maybe you just didn't try hard enough? I did get it to fit, you don't have to believe me because frankly I dont give a
. Not everyone has the resources or wants to drop the bank required to rock an ST220. I think maybe you forget sometimes that there are less than a handful (literally, less than five) in the US!
Overall, its clear to see that the plenums are MUCH bigger than the standard taurus piece, and the runners are much better too! Not too far from an ST220.
You build good machines, but its not always your way or the highway. It's taken me a while to realize that exact same thing....
And fwiw, I honestly hope you dont think I'm digging at you. Just friendly conversation.
