xspektrex
*Issue: Cooling Fans Not Coming On unless CTS is unplugged
*Known
- A/C has never worked since I got the car (previous owner indicated a possible leak)
- Turning on the A/C does not turn on my fans
- Coolant is being pushed in/out of overflow catch (water pump is functioning)
*Replaced:
- High/Low speed relays
- Gauge sending Unit (single post connection)
- CTS (2-Wire connection)
*Test's Performed:
- Jumper Test on High and Low speed relay sockets (fans work)
- Battery test on High and Low speed relays (relays click)
- Disconnect CTS (fans work)
-- Plug CTS back in and fans cut off immediately
*Assumptions at this point, as to the cause
- Thermostat has failed causing little to no coolant to get to CTS
- CTS wiring is shorting along the harness
-- All wiring under the UIM appears to have been electrical taped and not very well!
Tired of
fighting
with her and just want to drive her, Please HELP!:help:
*Known
*Replaced:
*Test's Performed:
Tired of
