WiredMotorSports
'98 SVT Contour (E0)
General
Vehicle Type Five-passenger/four-door
EPA Class Compact
Platform Designation CDW27
Built Kansas City Assembly - Claycomo, Missouri, USA (Each individually inspected by SVT)
Dealership (sold at) SVT-qualified dealerships (~730)
Production Run 5000 (limited)
Cost Invoice: $20,375 MSRP: $22,365
Competition Audi A4 2.8 BMW 328i Nissan Maxima SE Pontiac Grand Prix GTP Volkswagen Jetta GLX
Warranties
Basic 3 yr./36000 mi.
Drivetrain 3 yr./36000 mi.
Rust 5 yr./unlimited mi.
24/7 Roadside Assistance
3 yr./36000 mi.
Dealership (service)
Any Ford authorized service center
Engine
Name
Duratec
Configuration
Transversely mounted, 60-degree V6, cast aluminum-alloy block and heads (Cosworth Casting Technology), iron cylinder liners, fully counterweighted forged steel crankshaft, crankshaft windage tray, crankshaft's bearing journals induction hardened, aluminum-alloy main bearing inserts and rod bearing inserts, lightened modular-iron flywheel (2 lbs. lighter), sinter-forged alloy connecting rods, specially design aluminum-alloy pistons, fully floating piston pins, structural aluminum-alloy oil pan
Bore x Stroke~
82.4mm (3.24") Bore x 79.5mm (3.13") Stroke
Displacement~
2.5 liter/2544cc/155cid
Compression Ratio~
10.0:1
Horsepower~
195 hp @ 6625 RPM
Horsepower (at the wheels)
165 hp @ 6600 RPM
(measured by CEG member)
Torque
165 lb./ft. @ 5625 RPM
Torque (at the wheels)
148 lb./ft. @ (2700 and 4400) RPM
Redline
6750 RPM (fuel shut-off at 7000 RPM)
Specific Output
76.6 hp per liter
Weight/horsepower
15.8 lbs. per hp
Fuel System
Ford EEC-V engine-control system, Sequential electronic multiport fuel injection
Fuel Injectors
19 lb./hr. @ 55PSI
Valvetrain
Double overhead cams (hollow camshafts), cam-lobes made with high chromium content to reduce wear, 250-degrees advance on primary lobe, chain-drive, cam chains have hydraulic
tensioners, roller finger followers with hydraulic valve-lash adjustment, ovate-wire valve springs, four valves per cylinder, four main bearings, larger butterfly port throttles (34mm) in its variable-length intake ports, extrude-honed secondary ports
Extrude Honed
equalizes the diameter of the intake runners, when flowing both head and intake together this setup has produced a creditable 194 cfm at max-valve lift on the intake
Cylinder heads
Cast aluminum (with extrude honed secondary ports)
Intake valves
2 per cylinder, 32mm head diameter
Intake manifold
Dual runner induction system, airflow-tuned upper intake, cast aluminum plenum chamber, extrude honed internal surfaces (plenum and intake runners)
Secondary intakes
Open at 3900 RPM (3400 RPM at WOT)
Exhaust valves
2 per cylinder, 26mm head diameter
Exhaust valve springs
Ovate-wire
Throttle body
60mm bore (2.36 in.)
Mass-air sensor
70mm diameter
Exhaust manifolds
Steel tube (clamshell design)
Exhaust system
2.25 in. (57mm) quasi-dual (Y-spilt after the catalytic converter & the resonator) stainless steel, 2.5 in. (63.5mm) polished stainless steel tips, 40% less back pressure at 6000 RPM
Oil Cooler
Water-to-Oil Cooler mounted to left side of engine block with the oil filter mounted on its end, water returning from the radiator to the engine block first runs through the cooler
Radiator
44mm deep fins (from European Mondeo), redesigned front fascia allows more air in for better cooling (50% larger opening), pair of 25 in. "euro" cooling fans
Air Filter
Special conically shaped high-performance air filter (30% less restrictive intake)
Firing Order (Cylinders)
1-4-2-5-3-6
Idle Speed
750 rpm (Not adjustable, computer controlled)
Future Wish-list
"Ford designed the heads on the Duratec to incorporate variable valve timing if needed in the future." (from CEG member)
Structure/Body
Structure
Steel unibody
Coefficient of Drag (Cd.)
0.31
Drivetrain
Layout
Front-engine/front-wheel-drive sedan
Final drive
4.06:1
Transaxle
Five-speed manual (MTX-75, not the heavy duty version), short throw shifter, two spider gears, synchronized reverse gear
Clutch
upgraded - new springs and friction material
Driveshaft
Steel, with hardened yoke
Gearing
Wheels & Tires
Wheels
16x6.5 in. (406mm x 165mm), cast-aluminum, painted surface, 5-spoke, 49.5mm offset
Tires
P205/55ZR16 Goodyear Eagle GS-C, uni-directional tread pattern
Suspension
Front
MacPherson strut, lower A-arms, coil springs (with recalibrated -stiffer- spring curves), tube shock dampers (re-valved for SVT), unique 19mm stabilizer bar
Rear
Independent Quadra link design, strut (re-valved shocks for SVT), with one lower trailing arm, two transverse links, coil spring, 18mm stabilizer bar, design allows small amount of passive rear-wheel steer
Steering
Type
Power assist, rack & pinion
Gear Ratio
14.5:1 (on center)
Turns, lock to lock
2.7
Turning diameter
38.4 ft.
Brakes
Pedal
vacuum power assist
Front
10.94-in.(278mm) vented discs, single-piston caliper, swept area 232 in.2 (20.8% more), dacronet-plated (prevents rust on unswept areas)
Rear
9.88-in. (251mm) vented disc, single-piston caliper, swept area 152 in.2, dacronet-plated (prevents rust on unswept areas)
ABS
Ford 4-channel/4-sensor system, modulates and adjusts each of the four calipers every 10 milliseconds
Amenities
Included
Exterior
Black Clearcoat, Silver Frost Clearcoat Metallic, Toreador Red Clearcoat Metallic
Interior
Midnight Blue Interior, Perforated leather seating surfaces
Dimensions, Capacities, etc.
Wheelbase
106.5 in. (2705mm)
Length
183.9 in. (4671mm)
Height
54.5 in. (1384mm)
Width
69.1 in. (1755mm)
Ground Clearance
6.1 in. (156mm)
Track, F/R
59.2 in./58.5 in. (1504mm/1486mm)
Passenger Volume (front/rear)
52 ft.3/39 ft.3
Head Room, F/R
39.0 in./35.0 in. (991mm/889mm)
Shoulder Room, F/R
53.9 in./53.3 in.
Hip Room, F/R
50.7 in./45.5 in.
Leg Room, F/R
42.4 in./34.3 in.
Seatback adjustment, Front
85 degrees
Seat travel, Front
8.5 in.
Curb Weight
3068 lbs. (1393kg)
Weight Distribution, F/R, %
63/37
Towing Capacity (Std/Max)
1000 lb./1000 lb.
Fuel Tank Capacity
14.5 gal. (54.8 liters)
Trunk volume
13.9 ft.3
Oil Pressure
20 to 45 PSI (at 1500 RPM (hot))
Spark Plugs
Type: Motorcraft AZFS-22pp
Gap: 0.050 inch
Radiator Cap opening pressure
16 PSI
Fuel Filter
Motorcraft FG-800A
Headlights
9005 (high beam), 9006 (low beam)
Battery
55 AH maintenance-free
Alternator
130 Amp
Tune-Up Interval
100,000 miles (under normal driving conditions with routine fluid and filter changes)
Engine Oil
5.5 quarts
Cooling System
9.1 quarts
MTX
8.9 quarts
Fuel (type)
91 octane
Performance
0-30 mph 2.5 sec.
0-40 mph 3.8 sec.
0-50 mph 5.2 sec.
0-60 mph 7.9 sec. (officially) 7.1 sec. (un-officially)
0-100 kph 8.3 sec.
0-70 mph 9.3 sec.
0-80 mph 11.6 sec.
0-90 mph 14.8 sec.
0-100 mph 18.8 sec.
0-120 mph 33.3 sec.
Street start, 5-60 mph 8.0 sec.
top gear, 30-50 mph 9.6 sec.
top gear, 50-70 mph 9.9 sec.
0-100 ft. 3.3 sec.
0-500 ft. 8.4 sec.
0-1320 ft., Quarter mile 15.7 sec. @ 88.7 mph (officially) 15.4 sec. @ 91.5 mph (un-officially)
Top Speed 143 mph (drag limited) (officially) 150+ (unofficially, from CEG member)
Braking, 60-0 mph 129 ft.
Braking, 70-0 mph 164 ft.
Braking, 80-0 mph 228 ft.
Braking, 100-0 mph 351 ft.
Slalom, 100 ft. gates 64.8 mph
600 ft. slalom 67.7 mph
200 ft. skidpad 0.84g
300 ft. skidpad ?
Handling Balance
mild/moderate understeer
Emergency lane change maneuver
63.3 mph
Interior sound level
idle 50 dBA
full throttle 78 dBA
50-mph cruising 66 dBA
70-mph cruising 72 dBA
70-mph coasting 71 dBA
Engine RPM at cruising
2650 rpm (5th gear @ 60mph)
3490 rpm (5th gear @ 80mph)
EPA fuel economy (City/Hwy)
20 mpg/29 mpg
Range in Miles (City/Hwy)
290 mi./421 mi.
End
Specifications
Thanks to http://www.stuff.to/svtspecs.php
General
EPA Class Compact
Warranties
3 yr./36000 mi.
Engine
Name
Duratec
Configuration
Bore x Stroke~
Displacement~
Compression Ratio~
10.0:1
Horsepower~
195 hp @ 6625 RPM
165 hp @ 6600 RPM
Torque
Redline
Specific Output
76.6 hp per liter
Weight/horsepower
15.8 lbs. per hp
Fuel System
Fuel Injectors
19 lb./hr. @ 55PSI
Valvetrain
Extrude Honed
Cylinder heads
Intake valves
Intake manifold
Secondary intakes
Exhaust valves
Ovate-wire
Throttle body
Mass-air sensor
70mm diameter
Exhaust manifolds
Exhaust system
Oil Cooler
Radiator
Air Filter
1-4-2-5-3-6
Idle Speed
Future Wish-list
Structure/Body
Structure
Steel unibody
0.31
Drivetrain
Layout
Final drive
4.06:1
Transaxle
Clutch
Driveshaft
Gearing
Wheels & Tires
Wheels
Tires
Suspension
Front
Rear
Steering
Type
Gear Ratio
14.5:1 (on center)
Turns, lock to lock
2.7
Turning diameter
38.4 ft.
Brakes
Pedal
vacuum power assist
Front
Rear
ABS
Amenities
Included
- Supplemental restraint system: Driver- and passenger-side (air bags)
- "Safety Cell" structure
- Anti-Lock Brake System
- Passive Anti-Theft System (PATS)(disables ignition when activated)
- Articulated sport seats (10-way power for driver) with leather/vinyl trim. Includes adjustable lumbar support.
- White-faced guage cluster
- SVT suspension tuning
- Special SVT body/ground effects kit
- Air-conditioning/manual control
- Inner-aiming head lamps
- Premium Electronic AM/FM stereo cassette
- Power Equipment Group: Duel electric remote control mirrors, power side windows, power door locks, power antenna
- Rear window defroster
- Speed control
- Front floor mats
- Dual illuminated visor mirrors
- Remote keyless illuminated entry
- Particulate air filtration system
- Tilt Steering Column
- 60/40 split fold-down rear seat (releases located in trunk for safety)
- Variable-timed interval windshield wipers
- Remote decklid release
- Height adjustable front seat belts
- Child-proof rear doors
- Rear center 3 point belt
- Leather-wrapped steering wheel
- Leather-wrapped shift knob
- 5 mph front/rear bumpers
- No spoiler available
- Electronic AM/FM stereo with compact disc player
- Power moonroof with sliding sunshade
Exterior
Interior
Wheelbase
106.5 in. (2705mm)
Length
183.9 in. (4671mm)
Height
54.5 in. (1384mm)
Width
69.1 in. (1755mm)
Ground Clearance
6.1 in. (156mm)
Track, F/R
52 ft.3/39 ft.3
Head Room, F/R
Shoulder Room, F/R
53.9 in./53.3 in.
Hip Room, F/R
50.7 in./45.5 in.
Leg Room, F/R
42.4 in./34.3 in.
85 degrees
Seat travel, Front
8.5 in.
Curb Weight
3068 lbs. (1393kg)
63/37
1000 lb./1000 lb.
Fuel Tank Capacity
Trunk volume
13.9 ft.3
Oil Pressure
Spark Plugs
Gap: 0.050 inch
16 PSI
Fuel Filter
Motorcraft FG-800A
Headlights
Battery
Alternator
130 Amp
Tune-Up Interval
Engine Oil
5.5 quarts
Cooling System
9.1 quarts
MTX
8.9 quarts
Fuel (type)
91 octane
Performance
0-30 mph 2.5 sec.
0-40 mph 3.8 sec.
0-50 mph 5.2 sec.
0-100 kph 8.3 sec.
0-70 mph 9.3 sec.
0-80 mph 11.6 sec.
0-90 mph 14.8 sec.
0-100 mph 18.8 sec.
0-120 mph 33.3 sec.
0-100 ft. 3.3 sec.
0-500 ft. 8.4 sec.
300 ft. skidpad ?
Handling Balance
63.3 mph
idle 50 dBA
20 mpg/29 mpg
290 mi./421 mi.
End
Specifications
