Air Conditioning Compressor Cycling Switch Location?
Thunderwing
Hi,
Does anyone know where the Air Conditioning Compressor Cycling Switch is located on a 1999 Ford Contour SE 2.5L?
I found these troubleshooting steps (my compressor is not engaging).. but I don't know where the A/C Cycling switch is? Please help! Thanks.
A3 CHECK THE A/C CYCLING SWITCH
Disconnect A/C Cycling Switch C692
Connect a fused jumper wire between A/C cycling switch C692, pin 4, circuit 14S-CA17 (VT/OG) and pin 1, circuit 14S-CA38 (VT).
  • Does the A/C clutch engage?
Yes GO to A4.
No GO to A5.
A4 CHECK THE REFRIGERANT SYSTEM PRESSURE
Connect gauge set to port. High side reading must be above 169 kPa (50 psi).
  • Is the high side pressure above 169 kPa (50 psi)?
Yes INSTALL a new A/C cycling switch. TEST the system for normal operation.
No CHECK and REPAIR the refrigerant system for leaks or low charge or incorrect A/C compressor clutch air gap. TEST the system for normal operation.
A5 CHECK FOR VOLTAGE AT THE A/C CYCLING SWITCH - CIRCUIT 14S-CA17 (VT/OG)NOTE: Verify the switch is in the MAX A/C position.
Measure the voltage between A/C cycling switch C692, pin 4, circuit 14S-CA17 (VT/OG) and ground.
  • Is the voltage greater than 10 volts?
Yes GO to A6.
No GO to A20.
A6 CHECK FOR VOLTAGE TO THE DUAL PRESSURE SWITCH - CIRCUIT 15S-FA38 (GN/RD)NOTE: If the pressure is decreasing the A/C compressor cycling switch will be opened and no voltage will be seen at the pressure switch. The pressure must be increasing to see any voltage at the pressure switch.NOTE: Verify the switch is in the MAX A/C position and don't disconnect the jumper wire of C692.
Disconnect Dual Pressure Switch C882
Measure the voltage between dual pressure switch C882, pin 2, circuit 15S-FA38 (GN/RD) and ground.
Yes GO to A7.
No REPAIR circuit 15S-FA38 (GN/RD). TEST the system for normal operation.
A7 CHECK THE DUAL PRESSURE SWITCH
Measure the resistance, component side between the dual pressure switch terminals.
  • Is the resistance less than 5 ohms?
Yes GO to A8.
No INSTALL a new dual pressure switch. TEST the system for normal operation.
A8 CHECK CIRCUIT 15S-RE9 OR 15S-RE9A (GN/BU)
Connect Dual Pressure Switch C882
Measure the voltage between the PCM, C421, pin 41, circuit 15S-RE9A (GN/BU) and ground.
Yes GO to A9.
No REPAIR circuit 15S-RE9 or 15S-RE9A (GN/BU). TEST the system for normal operation.
A9 CHECK THE A/C CYCLING SWITCH C692 FOR OPENDisconnect the jumper wiring of C692.
Connect A/C cycling switch C692
Yes GO to A10.
No INSTALL a new A/C cycling switch. TEST the system for normal operation.
A10 CHECK CIRCUIT 15-FA12 (GN/BU) FOR VOLTAGENOTE: If the pressure is decreasing the A/C compressor cycling switch will be opened and no voltage will be seen at the A/C WOT relay. The pressure must be increasing to see any voltage at the WOT relay.
Disconnect A/C WOT Relay C465
Measure the voltage between A/C WOT relay C465 pin 3, circuit 15-FA12 (GN/BU) and ground.
Yes GO to A11.
No REPAIR circuit 15-FA12. TEST the system for normal operation.
The A/C cycling switch is mounted on top of the suction accumulator (dryer) located on the left side of the radiator ( drivers side). Hope that helps.
