Big G
My g/f 95 contour won't start all it does is roll over. I thought maybe it was the fuel pump which I changed out and that was not the problem. changed out the fuel filter and didn't get nothing either. I have gas to the fuel rails. We checked it at the little pressure thing (looks like a valve stem right by the rail) and there is pressure when you turn the key on. I pulled out all the plugs and cleaned them and check for spark,which all have. I'm lost for what has happened to it. Jumped time? :shrug: I did the self test on the computer and it was flashing 551. I can't remember what that is off the top of my head but I know it's set at the factory and can't be changed.(so it says in the hanes manual. Any ideas before I take it into the garage? All fuses are good, Everything I checked was ok. It was running fine the day before then nothing. Thanks for any help. :help:
Big G
95 Tour V6/Auto.
Big G
95 Tour V6/Auto.
