Anyone changed the AC Compressor clutch field coil
Heywood
Montreal
I am replacing the AC compressor clutch and it calls for special tools to remove and install the field coil. Does anyone know what these tools are and where to get them or a work around? Also, is it possible to do this with the compressor in place? The instructions say to use a 2 claw puller to get it off, which obviously won't fit of you don't remove the compessor.
Instructions I'm working with attached.
Thanks.
  • ACClutchCompressor.pdf
I just got my AC/clutch replaced by a friend mechanic, and you have to take the whole Compressor of the car. Blowes cold now, 38 degress cold charged me $160.00 and that was a friend. So local shop is probably twice as much.. It's not an easy task, you must have the right tools and know how.. Plus you must recharge the system and add the right AC DYE, and PAG Oil..
