FireKnight099
Continuing from the previous topic...
Hello everyone, everything good? I'm in the final details of the restoration, now we have it working, running, currently doing the final suspension part
currently what has been done...
-button trim and sunroof machine was installed
-instrument cluster cover trim was installed
-All finishes were reinforced with fiberglass behind to avoid cracking.
-LEDs were placed in the breaklight and installed back in place with the cover
-spare tire lock has been redone
-new ford fusion trunk shock absorbers
-radio repaired and renovated with new LEDs and bluetooh connection (Retro mode)
-doors and locks and lubricated glass tracks
-I had the driver's side air diffuser produced on a 3D printer
-I bought the driver's electric seat control
-front airbag crash cells installed
-original temperature sensor installed and working
-How I used a Ford Fusion oil switch for the dashboard light and it works in reverse. I had to reverse the polarity with a relay
-sunrooffilm removed
-the carpets were removed, washed and cleaned and repainted (fabric paint)
-Driver and passenger seat rails with restored, painted and oiled rails
-suspension almost finished, with a rear bar that was bent to be changed
-the entire rear frame was painted and the bars
-a new flexible pipe was made from the exhaust manifold to the rest of the car's exhaust
-All electric motors for the driver's seat were purchased and already installed with the new threaded mechanism from the Mustang
-new tires installed
-rear bumper chrome strip installed
-rear bumper reinforced with fiberglass core.
Many things are coming, but now missing:
-I bought a new power steering pump, I tried to restore the old one, but the repair kit doesn't last long...
-check all speakers
-change the radiator water tank, it has already been purchased
-Possibly think about an oil cooler, because the pressure drops a lot due to the temperature.
-check for gasoline leaks when filling the tank
-restore the entire air conditioning system and open the compressor to renovate
-fix all the leather on the car seats
-finish the rest of the car bodywork
-cover the arch of the side spoilers with fiberglass
-Attach the driver's side headlight again as it is loose
-make the sunroof part with a 3d printer too
Today let's say that the current state of the car is 70% redone. but it is never more to say that things appear. I believe that by the end of this year I will finish...
Next year the car turns 30, here we have the right to exchange license plates for collector plates, we will also do that.
Follow the link to the photo folder in the cloud, I believe that in a month I will upload the new videos.
Thanks!
Brazilian Contour 1995 v6 Restoration continues , and its running!!
Hello Everybody , I'm coming from this presentation topic I posted in 2023 : https://www.contour.org/forums/threads/brazilian-1995-duratec-v6-restoration.71228/#post-998759 I didn't post it due to lack of time, but I would like to share it with you here in the general discussion, as there is...
www.contour.org
-check all speakers
Microsoft OneDrive
1drv.ms
Thanks!
