Mine broke as well. At first I was going to plastic weld it, just take my soldering iron and melt the plastic together, but that piece is under a lot of stress once everything is screwed down and clipped in. So, I took a paper clip and bent it so it looped around the screwhole, then looped it over the top of the plastic piece (this makes more sense with a picture, so I will put up a picture later), so that way when I screwed it down, the paper clip pulled on the whole piece and not just the tabs. If it breaks again I'm going to plastic weld it be adding extra plastic and melting it on. :laugh:
