cclngthr
If people are getting a P0420 or P0430 code, cat inefficiency code, one thing to look for in properly diagnosing it is where the long term fuel trims are at on each bank and o2 sensor voltage. Sensor 2 voltage should be within .100 of 1 volt at idle and at a steady rpm on a 1 volt scale. It can vary depending on the engine, but it should be above .650 volts at idle. Usually .800 is considered normal. LTFT should be below 5% on each bank at idle, the lower the better.
The main problem with both the Duratec and Ztec is carbon buildup. This causes false cat codes and makes it run lean. A regular cleanout is my recommendation.
Materials
WATER (plan on using at least 1 gallon, possibly more)
1 16 oz can of seafoam
1 squirt bottle, with a stream spray attachment.
I recommend slowly pouring water in the TB rather than the vacuum line. May have to do this fast enough with engine rpms at 3,000 rpm at hot engine temps. What you want to do is fog and steam up the engine everywhere. A vacuum line may not allow steam to get everywhere. After a while, try to pour enough water in the engine at a lower rpm to bog it down and let it die. Let sit for 20 minutes to let the steam cook in the engine. Restart engine (will be difficult to start) and rev up engine rapidly to shove crap out the exhaust. Should see a lot of gray smoke. Once smoke is pure white, let engine idle until running smooth.
Next, use the squirt bottle with seafoam in the TB and as you are spraying it in the TB, rapidly throttle the engine from idle to WOT fast enough not to overrev the engine, but to clear out the engine of carbon buildup. The rapid WOT throttle is to let seafoam into the EGR passages and through the valve itself. You should see black soot coming out of the tailpipe.
Did this with my contour which had these codes and everything is fine now. Will need to run the car on the highway a while to clear out the cats.
Materials
