Connecting rod bolts...?
Olofson
Be Gentle I'm New Here
Sweden
Hi!
Since this is my first post here, maybe I should introduce myself. I'm basically a crazy swede building a Westfield SEiW (modernized Lotus Seven) with a Duratec V6 2.5 and a Honda S2000 gearbox. I also have a daily driver 1997 Mondeo V6 with a few minor mods. (Slightly lower and stiffer springs, uprated shocks, K&N drop-in replacement air filter, stainless 2.5" full flow exhaust.)
Anyway, here's the problem I'm having right now: I've managed to spin a rod bearing in the Westfield V6 engine. (Strangely #5, standing still, at low revs... Probably due to prior damage and/or the engine sitting too long without oil.) No damage to the crank or anything. I did find a supplier of uprated bearings nearby (Clevite and others), and ordering Clevite 77s from the US is also an option. No problem so far.
However, it seems impossible to find new rod bolts...! (These are torque-to-yield on all revisions, right? This is a 2.5L from a 1999 Cougar ATX.)
Ford around here does not sell any parts at all for this engine, except for new blocks. They don't even recognize the part no. (F3LY-6214-A?) No luck with Motorcraft in the US either. All I've found so far is complete Ford rods (which I apparently can't even order, as I'm not in the US) and various expensive, overkill racing rods (I won't be needing more than some 400 bhp in a 600 kg car just yet ;-)) - no bolts; Ford or others.
Does ARP or any others make bolts that would fit the original rods? Can I actually order a set of Ford bolts anywhere?
Ford Engineering part number F2LE-6214-BA
Ford Service part number (North America) F2LY-6214-A
Ford Service part number (Europe) FINIS-6810980
Mazda Service part number AJ0311214
If all else fails, you might try a Jaguar dealership since the engine is also used in the X-Type, S-Type, and XJ.
hello buddy, if u try y2kfords they should have them for you, ive just ordered from them as well with the bearings as ive put diamond racin pistons as i am soon gonna either get a turbo kit or a supercharger kit and wanted the bearings and bolts new as u said they are TTY, hope this helps : http://www.discountfordpartsaty2kford.com
Thanks everyone! I'm looking into ARP or similar bolts, but if that fails, at least I have some options.
I did get a reply from Ford Sweden eventually. It's supposed to be possible to order bolts using the 6810980 number, despite no parts for these engines being in the catalogs.
