So my brake lines are leaking and I need to drop the gas tank on my 98 SVT to gain access to the rear lines.
I have the exhaust and heat shield removed so I can get to the strap bolt on the driver side. So the tank is somewhat ready to start dropping but I need to empty the tank first. I tried putting a tube down the filler tube to see if I could get into the gas tank to siphon the gas out but that didn't work. I'm guess there is a something in the tube that will prevent gas from going up that tube which is stopping me from getting a tub down into the tank (ran into this problem when doing a fuel pump on my girls Jimmy).
So, how do I drain the gas?
Its close to a full tank with only 60 miles put on it since filling it up so it would be quite heavy and awkward to drop while it has this much gas in it.
Also, the manual says to press the tabs and pull the ring out to remove the filler tube from the gas tank? Is it really this simple or is there a trick I should know about first before I start?
Any help would be appreciated as I need to get the tank out so I can start running my new brake lines.
Thanks
Thanks
