Nick Buol
My headlights and interior lights (dash, overhead, etc) flicker when driving. Not horribly bad, but enough that it gets annoying. I've had this problem for a while and have a new alternator as of a few months back (old alternator failed, so it wasn't a replacement because of the flicker).
Anyway, I was looking at the old "wiring fix" threads, and it seems straight forward, but I have a question.
Here is what I've found elsewhere here (questions below picture):
1. cut red wire from 3 wire plug from alternator.
2. extend the red wire STILL HANGING from the connector to the main CHARGING wire.
3. the red wire going into the harness is no longer used. TAPE IT UP!!
Heres a Pic of the final wiring. The PINK wire is your new extension.
OK, but there are TWO red wires in the diagram. I am assuming that the larger red wire is going to somewhere else under the hood, but I wanted to get clarification.
So you cut the small red wire, tape off the area marked with a black 'X', then add the "pink" wire and connect up the small red wire to the same connection as the large red wire via the pink wire?
Is that black, rectangular piece at the top of the picture a resistor?
Sorry, but I am not in front of the vehicle. I am hoping to try this tonight at home, and want to plan ahead.
Thanks for the insight.
