james1767
Going to be installing the new updated Ford Motorcraft fuel pump that requires cutting out the old locking ring from the bottom of the fuel tank. I've read plenty of discussion that the plastic tabs that hold the locking ring into the tank can be cut with a razor knife. Anyone know how to cut these, i.e. is it obvious once you look down at them, or is there a specific technique? I would assume you hold the razor lengthwise on top of the tab and then push DOWN to slice the tab in half so to speak, or do you slice it from the side? The Motorcraft pump came with pretty good instructions all warning about not pushing or pulling on these tabs due to potential damage to the fuel tank, and of course they specify using their special tool to cut the tabs off.
Any thoughts would be appreciated - also any more secrets to getting the fuel line off the top of the pump - seems like general opinion is just keep the two-tabbed plastic ring around the fitting and squeeze until it pops off.
Thanks all!
Jim
Thanks all!
Jim
