Mr_Buddha
Ok, I cleaned my UIM/LIM last weekend. Ended up hydrolocking one of the cylinders with carb cleaner.
Now thankfully, my battery & starter were weak, and I bent nothing! I fixed the hydrolock, changed the oil and now I can get the engine to crank all day long, but not fire. I verifed spark by pulling a plug and watching it spark.
I found that I am not hearing the fuel pump prime when I turn the key. I found the inertia switch was tripped, so I reset it. I can feel the relay flipping if I have someone turn the key to start while I hold my hand on the relay. I checked for voltage at he inertia switch and found it to be a normally open circuit? it only allows 12V through it when the button is pushed.
I cannot find a accurate electrical diagram on this circuit. Can anyone help point me in the right direction to look please?
