svtcont98
I did a compression test on bank 1 yesterday because of the car's lean condition, bad smell, and power loss. cylinders one and two came back 185-190psi, cylinder 3 reported 80psi. : (
When i put the spark plugs back in, i heard a new knocking noise and shut the car off. i pulled the spark plug on cylinder 3 and it was crushed. i don't think the other's are damaged and haven't checked the others, but they must be okay because the car starts fine and idles okay. i put a new spark plug in and it ate that one too!
the plugs were torqued to spec and they were fine (albeit white from being lean) before i reinstalled. What is happening?!
