photodreamer
- Joined
- Dec 11, 2006
- Messages
- 11
Hello, I've been noticing some trouble with my 1998 Ford Contour SE Sport with the Zetec 2.0L 4 cyl engine.  A few months ago I noticed that the electric cooling fan was staying on all the time.  Just in the past few weeks I noticed that the temperature gage is higher than normal at times.  About 3/4 of the way across.  When it does that my transmission seems to be bogging down.  It will make a low vibration when i press the gas and the RPM's won't go up unless I press the gas pedal harder.  If i press the gas slowly the RPM's won't go up.
I'm not sure if this is related to some sort of sensor. Maybe the one that's causing the fan to stay on all the time? I checked all fluids and they're topped off. Including the transmission. I'm very broke right now and out of work which is why I haven't fixed the fan from staying on. But I was just curious if anyone knew what could be wrong?
Thank you
Thank you
	 .  How is the condition of the wiring harness in the engine bay?  Your Check Engine Light is probably on.  Go to Advance or Autozone and have them scan the code(s) (free service).  Then post the exact code(s) here.  It could be a relay or sensor but get the codes and we should be able to diagnose more.   To download an Owners' Manual (free)
