Parts needed:
Screw driver, long and short.
Dremel or hack saw
Pliers
Part 1. First we will start off with the typical screw driver.
Make sure the screw driver fits snug inside the screw. If it doesn't then you will most certainly strip the screw immediately.
Once you find the correct size place the screw driver firmly against the screw applying as much pressure possible to the back of the screw driver while your other hand turns it.
If you remove the screw, then remove the other screw and your done.
Part 2. If it is still not turning and the screw is not stripped.
Find a really long screw driver and try again. If it still won’t turn, Grab a pair of pliers and place them onto the screw driver like so.
Then apply as much force against the screw and turn the screw driver with the pliers. 80% of the time the screw will break lose.
IF YOU STRIP THE SCREW. Continue Reading!
What you will need is either a hack saw or a dremel with a cutting wheel.
Here we will place the dremel (Hack saw) and cut a slot into the screw like so
Once the screw is cut. Take a really long screw driver and again apply pressure and try to turn the screw.
If it turns then great! Continue to the next screw.
Once both are out. Then your done.
Dremel or hack saw
Pliers
