blu_fuz
New Member Classroom vulture
Remove fuel rail and place the hose in a bucket at the end of it.
How to activate fuel pump using a battery trickle charger:
-Trace the wire harness wires and find the two indicated below.
-Brown wire with yellow stripe is negative.
-White wire with black stripe is positive.
It will spit and sputter when it empties like when you are done taking a wiz in the toilet. This helps for the people that are parting cars and want to save the tank or if you want to clean your tank and re-use the fuel after you are done. I hope this help someone.
